Go to app info, top 3 dots, allow restricted settings
this app cant be the default SMS app it does not have all requirements
- fixed a few bugs that made problems for some replies
- fixed the error to prompt for default SMS app
Works perfectly
- Edit the auto reply
- added refresh button to trigger OTP check
PLEASE I CAN’T IMPROVE WITHOUT FEEDBACK…
- auto start service after reboot
thanks @chatzie for the feedback
PLEASE… I CAN’T IMPROVE WITHOUT FEEDBACK
- Edited Launcher Icon
- Notifications For New OTP Messages (if you don’t won’t notifications remove the notifications of the whole app)
Finished With That Any Idea You Won’t To See On Your Phone?
Yes i wanna be able to edit otp like delete and copy
copy is enough?
HUGE update
- Complete New UI
- Copy OTP
- Delete OTP
Next Filtered Utility App — What Should We Build First?
Help choose the next practical tool for Android users. Two ideas. One vote.
Option 1: Halachic-Aware Do Not Disturb App Automatically toggles DND during Shacharis, Mincha, Maariv, and Shabbos/Yom Tov, fully offline.
Zman-based silent mode (no GPS or internet)
Shabbat/Yom Tov integration from candle lighting to havdalah
Minyan Mode: temporary DND toggle
Custom vibration/silent/whitelist settings
Pre-Shabbos reminders
Ideal for users who want respectful silence—no distractions.
Option 2: Call Recorder call recording built for Android phones.
Tap-to-record incoming or outgoing call
Saves to app with timestamp + label
Fully offline, totally deterministic
UI designed for non-touch phones
Which one would YOU use first? Vote + comment below with your preference, feature ideas, or other tools you’d love to see built.
- Option 1 DND App
- Option 2 Call Recorder
How about adding this to the vote? Looking for App Ideas - #31 by kosherboy
@HalachiDev Thanks so much!
p.s. can you change your name? Current one is confusing…
what do you mean ‘name’ package or on the credits dialog?
username on the forums
how do you wont the app to get your sent messages without being default?
np but also change all threads and discussions where i was tagged…
I’ve used an app called pushbullet that was able to do it without being default.
send me the apk lets check out how they do it
