I just wonder if there is an adb command to do whatever shizuku tells the phone to do this adb command does because i was told that usually what an app could do an adb command could do the same thing
What do you mean by
Whatever the shizuku app does to tell the phone to make the mouse click maybe an adb command could tell the mouse to do that
And where would this adb command be executed?
Using adb on the computer after i put on the mouse
and why is that better than the mouse working with Shizuku and starting Shizuku with adb on a computer?
I want to take out shizuku totally because its not so practical for the average user and instead figure out what shizuku does and see if there is an adb command to replace that because anything that an app could do adb could also
please explain whats not practical about shizuku
So you want to use the mouse while connected to the computer? That is not a use case I am targeting.
Performance would also be much worse than system level gestures directly in the device.
No i want to figure out what shizuku does and see if i could just use an adb command instead do a one time adb command to grant the permission that shizuku and then use it as regular like any other virtual mouse because shizuku is not practical because every time you restart your phone you need to restart shizuku with a adb command
Yes we understand it’s not convenient but again that is the trade off. The only other way is if you are rooted.
If you have a better way let us know.
If it would be possible to execute an adb command once to give permission to an app to do whatever Shizukus doing, then Shizuku would give such an option.
Its not possible.
Just thanking you for your app.
Its amazing how simple it is to use, and the shizuku version works perfectly on Android 11.
Any issues or hiccups?
You installed it on your sonim
No.
Everything works perfectly.
Yes.
Some more changes I need to make before the next release but here’s a preview of the changes: added a standard cursor (to use in conjunction with the grid cursor or if you prefer it over the grid cursor) and added remapping. Still with Android 11 support through Shizuku.
can you post it for testing
Will have one ready by tomorrow.
