Like I said try pixel 5+
use this to generate
yup
On verizon, can make calls but all incoming phone calls go to voicemail. On a qin. Can that be a CDMA-less issue?
yes can be can you receive or send text ?
Yes both sending and receiving text works
Just incoming calls don’t. Not sure what else it can be
then probably not a CDMA less issue
call your service
I had this issue even with cdma-less on problem was that phone app wasn’t updated. Is it updated?
turns out it was something on verizons end. when testing sms - didnt realize it was rcs that worked, sms didn’t. so it was cdma-less in the end
It’s always the same issue at the end…
Is there a way to do it online? I get my service from Verizon directly and my qin is randomly dropping service and no incoming calls/texts
That is the famous Issue with the Quinn Phone
I have it for about a year no issues just switched to Verizon now
Don’t have a Quinn just heard from a lot of people that they have service issues
Generally you have to call not always does the customer service agent know what to do it can be annoying sometimes
I find chatting with Verizon much more useful than calling from experience, as u can clearly type “activate cdma-less provisioning feature 83856” instead of telling them over the phone and them not hearing/misunderstanding what you said.
So I called them up and turned it on, I can call but I have issues with messages
And it keeps dropping service
