Interesting.
i was happy to find one version that has on screen keys. Vs the left soft key that didn’t work on the version you linked. Though I’m if your version works on the other model kyoceras and or LG?
Interesting.
I never had any problems with it.
I think that I tried the ones on their website, and either it has iab or it didn’t work, but I remember trying it and then taking it off
The hidden settings apk seems to have TikTok banners flashing across the top.
If that SL has the same I’ll pass on that version.
i dont remember what is has (could be from iab to ads to just didnt work), but if it was just ads, you could use blokada and block them. i just realized that i dont need it going through my contacts so i uninstalled them on my new phone before giving it permission to go through my contacts
I’ll upload a mod with ads removed.
I’m just not very good at remembering to remove ads, cuz I use blokada.
I don’t think that it works so well on the Kyocera e4810, I tried it some time ago, maybe I will try it again tonight
The earlier mods of this app were tested and worked on the Kycera DuraXe Epic e4830.
There’s no reason this should be any different.
The one you uploaded didn’t work and has tons of ads please take it down.
I did a more thorough job this time, damaged links instead of just disabling activities.
There shouldn’t be any ads, but let me know if there are.
There are some differences between them, I was told that button mapper no that one was able to open up android setting, like the ones on a smartphone, but when I tried it on my phone, it opened up the normal setting that I have now
Button Mapper/Buttons Remapper/Key Mapper + Power Shortcuts, should be able to open whatever Hidden Settings can, +++.
So if button mapper wasn’t able to(the original) then Idk if hidden settings will be able to. Will try to test out later tonight
doesnt show up on kyocera e4810 after downloading.
any way to fix it?
what i uploaded is arm64 only so it wont install
i had tested it (a different build) on the e4810 it kept jumping
i didnt play around with it to much
if there is a need i can try more
ok.
I would like it, but if just me then you probably wont do it.
can you tell me how you would do it so that maybe I can do it myself?
here is the armeabi-v7a
it wont work well on the e4810, as you will see
should i even try it?
may as well
maybe you will find a fix
like setting the dpi
