What if soemthing corrupt happens and the phone tries to go into recovery? It will just brick?
after fastboot -w? what should happen?
Thank you, I’ll try it.
Does this command work on Kyoceras and TCLs? If not, how can I block recovery?
Anyone know?
Anyone have the boot image without recovery so you can’t factory reset the phone for the cat s22?
The cat has a separate recovery partition (I think), unlike the qin
so is there any way to block the recovery menu so the phone cannot be factory reset?
never played with the cat too much, so not that i know of
ok thanks
do you have this for the cat s22, so you can’t factory reset with recovery menu?
