I reflashed my TIQ Mini M5 and when I turned it on it just shows a black screen with the words Fastboot mode. How do I get out of it and back to my phone?
Flash the stock ROM Iâm actually looking for it so if you find it please post it thank you
Maybe @william can help with that.
Mtk and SP flash both donât detect it since the screen is on saying fast boot mode
Why doesnât the command ââfastboot rebootââ work?
How do I type that in??
Into your computer im a little confused
MTK wont detect it while it shows fastboot mode
Why do u need mtk to detect it? Just type into your terminal how you flashed fastboot reboot. im a little confused
I flashed via MTK client and this happened. Not sure what you want me to do from there. Theres no terminal
Oh why would flash through mtk client use fastboot regular.
do you know how to flash through fastboot
No - I dont know how to use fastboot
Do you have a folder downloaded on your computer called platform-tools (where adb is located)
Yes
Instead of typing anything about adb type the command fastboot reboot
This whole thread⌠Yoish⌠(3rd time today)
On TIQ M5, I ran fastboot flashing unlock
. Pressing volume up to confirm didnt do anything. How do I confirm?
doesnât work. you need mtkclient, autoboot, reboot fastboot, reboot.
Can you tell me the commands? The ones I tried did not work at all
