How do I update to the KEFS version?
In the software update in settings it says that my device is up to date
That doesnāt make sense. KEE7 is a very old software version. Do you have a good Wifi or Data connection?
I have a great wifi connection and it says my device is up to date
Maybe I need to update in a different way?
Give me a minute. Iām working on it
Have you flashed anything to this phone previously?
no
Is this the new model or refurbished?
I donāt know.
Is there a solution?
Same happened to me once. I never figured it out. I had flashed VB stuff with disable verification.
What is the command to update through Adb? Maybe try that.
6 posts were split to a new topic: Modifying Apps4Flip TCL Flip 2 ROM
I updated to KEFS!!!
Can you tell us how?
My guess is that he had a bad wifi or data connection before, and only now the phone chapped that it wasnāt up to date. As I expected. Had I had time before, I would have sent a package to manually update the phone by flashing the necessary partitions, but the safer option is through the phoneās system update app.
Did you figure out how to flash the ROM, or do you still need help with that?
As for why I couldnāt update the version, itās because I had a filtered WiFi connection and it wouldnāt let me update. I need help with flashing the ROM.
Just wrote a guide:
