Whats normal vela?
K will try
no arm 32
Perfect
Tcl ppl please try downloading and using vela voice mic on this build. Will polish after confirmed working.
https://github.com/alltechdev/vela-dpad/actions/runs/29858729867/artifacts/8506720541
Also any armv7 phone.
On the sonim xp3800 there are no softkeys so there is no way to search and when pressing back it is very slow response
Where did you download the apk from
Github Releases
Give me the link
on kyocera e4810 i tried searching, but it was only letting numbers… could be it was an older version, downloaded motzaei shabbas.
yeah, it is. unless you updated from the app itself, when the new releases came out.
Its the one in your github repo
Release Vela 0.0.245 · alltechdev/vela-dpad
newest one.
use tt9, the default keyboard does that on some phones (the default keyboard will not recognize some apps that weren’t made for the phone)
Any plans to lower min SDK version?
Couldn’t get it to install on a Kyocera e4610 or an exalt.
Nah sorry don’t want to get into that
Tried that, goes insanely slow though… Idk if it’s the old version or just the 1gb ram on the phone
What about @keepitkosher ?
Are you interested in lowering the min SDK?
If he does I’d be able to. Also wondering how the app would fare with such an old webview.
