Fixing accessibility problem on Qin F21 Pro
somone confirm this!!! i was able to swipe out of egate and it still worked
the qin has a bug that affect all acsseibilty apps so i was testing solutions using the FNG once i found a solution i tried it on egate and it worked
Write exactly what you did and I’ll try to recreate it
i posted it above nothing different eGate - Android MDM - Version 1.33 + - #63 by ars18
but maybe it only works on the xda rom
did you watch the screen record
Yes
okay i rebooted and it stopped working when i swipe out of egate -
Yep lol
If you have the head for it, explore the services.jar in the f21 pro ROM.
smali smali smali I hate it
now i cant even get accseisibilty to work on egate even if i dont swipe out of egate
i feel like it has saomething to do with egate because the FNG was working accross reboots and when i swiped out of it and egate was messing not only with its own accseibilty but also FNG
i deleted all duraspeed related files and egate is back to working when i swipe out of it and it still works accross reboots. i saw in accseibiltiy setting that when you swipe out of egate it says “Not Working. Tap for info“ and then after a few second it goes back to “on“
and FNG is working - can somone try this out and tell me - any other tests i should try out
i deleted these files
/system/etc/init/duraspeed.rc
/system/framework/duraspeed.jar
/system/framework/oat/arm/duraspeed.odex
/system/framework/oat/arm/duraspeed.vdex
/system/framework/oat/arm64/duraspeed.odex
/system/framework/oat/arm64/duraspeed.vdex
i think the other things i changed (the ones i posted earlier lo maala vlo morid)
I’ll try it out.
This seems to work as well, without modifying system files.
Running after exiting from recents
# Kill the app if running
am force-stop com.oss.egate
sleep 1
# Launch the app
am start -n com.oss.egate/.MainActivity
sleep 0.5
# Disable accessibility
settings put secure enabled_accessibility_services ""
settings put secure accessibility_enabled 0
sleep 1
# Re-enable accessibility service
settings put secure enabled_accessibility_services com.oss.egate/com.oss.egate.MyAccessibilityService
settings put secure accessibility_enabled 1
input keyevent 4
im confused how does that help - also that would only work for egate what i did seems to work for all accseibilty services now i just have to see how not having duraspeed affects me
yeah thats what I’m afraid of
everything seems fine for now ill keep you posted - i backed up all the files just in case
anyone try it out??
