Fixing accessibility problem on Qin F21 Pro
duraspeed whitelist + looping script to detect crashes and turn accessibility service for crashed app on/off twice.
Janky, but works like a charm.
how do i make a duraspeed whitlist - maybe that alone will work for me
Yes. Didn’t work for me.
Full solution does not require removing duraspeed.
# /system/etc/duraspeed/configuration.xml
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<configuration>
    <PlatformWhitelist>
		<App1>com.example.yourapp</App1>
    </PlatformWhitelist>
</configuration>
Thanks @KosherFlipper
the whitelist alone worked for me - thanks so much - your rom seems to have antoher issue that mine doesnt
Pull your super and send it to me?
Something’s gotta be different in your ROM. Maybe you don’t remember changing something?
I flashed 1.1.1 and tested with whitelist alone, did not work for me.
whats the best way to send it to you uplaoding to drive takes too long
I dunno. Cloud service would be your only option.
drive it is ill send it when its ready
is the whitlist supposed to say app1 on every line
upload gonna take awhile
fng gets reenabled quick but egate takes a couple seconds
@dfrydman check this out
FYI, i did not add functionality to create the file if its not there yet, only append to it.
Goal would be to have a textbox that the user can input a package name to.
how does it work. i pmed you the super
@FlipAdmin can this feature be built into egate - meaning it will create the whitelist for egate and maybe even a feature to add other package names to the whitelist
never mind i see how it works really cool but im more of a manual kind of guy
Just does:
mount rw
append app to list
If anyone wants to try it, without flashing a new rom (needs an internet connection, RW ROM, which I believe 1.1.1 is, AIV Google definitely is, and root):
Will bake this into a ROM eventually.
This will fix accessibility for the apps below.
Includes egate, TripleUMDM, and Fluid Navigation in the whitelist.
1. Install this module and reboot (won’t work without reboot).
2. Install this app
3. Press “Install Fix Module”, wait a few seconds, then check in magisk to make sure it’s installed.
4. Reopen the app and press “Update Whitelist & Reboot”
5. Open one of the apps, then open accessibility settings. Swipe the app out of recents and watch it go back on.
Feedback greatly appreciated.
Pull requests MORE THAN WELCOME
https://github.com/alltechdev/duraspeed-whitelist/blob/main/configuration.xml
REPO:
i was able to turn off egate in those 5 second only the first time i swipe out of egate - it looks like im having that thing you mentioned about first time being stronger shutdown or something - but this sounds like it can be fixed - also i feel like when i deleted duraspeed it would take much less time to start up
screen record https://drive.google.com/file/d/1iCoZ557iavnPygLsNI7v9pzNyW7vgU_d/view?usp=sharing
i think its getting worse now it takes like 10 seconds and sometimes fails entirely
