What do you mean? I didn’t remove it.
Works for me. Try again.
I just requested access
Got it, thanks
Just saying, button mapper and kosher ROMs don’t go together
Why?
Won’t say here, but believe me…
does this apk work properly on the kyocera e4810
How can i set that message plus as the default messaging app? on the e4810
For some reason this apk for message + keeps crashing, it doesn’t even open. and the latest apk i pulled from one of these sites is showing its not supported anymore please switch to new messaging app. anyone with a working one?
Tried on 2 different E4810. Both didnt work. Though 2 weeks ago i got one to work just fine.
I don’t think the flip phone version of Message+ works on the e4810.
It only works if Installed via adb and not through file manager/Bluetooth
I installed it via webadb.
The weird part is I just installed one around a week or two ago and worked just fine, now can’t get any of them to work except for the Android version of it.
But the Android version of it is so not compatible everything is made for a touch.
use the one from Uploaded Apps Thread - #10 by sams-club
That’s what I used last week worked just fine, tried it again on two different devices last night and it was a no-go.
no idea
You need to set it as the default messaging app first, after that it will open normally, also you can replace the stock messages on the main menu to message+
I can try again. And see if that helps.
So you suggest run a command to sets that app as default then open message plus?
You can do it from the Kyocera itself too if you can get to app settings
This app can help you get to it
You could also just press “app info” when you try going into message+ before its set as default
