Google Maps picture blocking
Gotcha it’s a fragment in the main activity, so ifw definitely not happening.
Try blocking these:
speechs3proto2-pa.googleapis.com
geller-pa.googleapis.com
Will probably break voice though
Ask me after shabbos needs more exploration
Edit - scratch that (ask me later).
In order to try those URLs if they work what is the ADB command to do that?
No. And they won’t work. Id honestly have to write a whole article to explain
So you’re saying from your end you don’t see a solution?
I do. But not simple
Anyone have the latest domains to block for the latest version of Maps to block pictures? Or are we still at the older version?
What are the domains to block ask maps?
Can’t work that way fully.
Was there an update in regards to this?
Is there a way to block these images as well?
Use older version.
They don’t expire?
I’m using version 25.32.00.790560726 works fine.
This version still has images that are not fully blocked
Which images? Which URLs did you block?
You’re right, I thought it blocked those as well.
Try version 25.16.03.747108139.
Can you post a link?
https://www.apkmirror.com/apk/google-inc/maps/google-maps-25-16-03-747108139-release/google-maps-25-16-03-747108139-2-android-apk-download/
