Which devices does eGate block hard reset, specifically flip phones
I don’t know that there is a list anywhere. It’s more reliable to delete the recovery partition. Technically, the “block hard reset” button doesn’t block it. It just uses FRP to brick the device if it does get reset. I’m thinking of removing that function, as deleting the recovery partition is a better method anyway.
watch out…
some phones need recovery to boot
Do you get a warning before resetting it that it will get bricked? I think it’s very important that this is clear.
Deleting the recovery is a complex task and requires root
u can do it through fastboot
No, I really need to change that.
How?
Dont forget the bootloader needs to be unlocked…
And on Samsung devices you know hownto do it? Samsung doesn’t work with fastboot
Well, if you’re messing with Samsung devices, I certainly hope you know what you are doing.
There is always ways to bypass frp its not that hard
Yes, that’s why I don’t see a future for using it as an anti-reset strategy.
But even if you delete recovery wouldn’t you still be able to reset with Fastboot?
If we’re talking about resetting via recovery, then how can eGate give a warning?
Are those ways as well known as resetting via recovery?
Do they need a PC?
Because if the answer to either is yes, then there is still value to blocking hard reset via FRP.
No, and yes.
It can’t. Resetting via recovery wipes eGate.
Just have to write something here because of the forums strict rules.
Screenshot_20250409-222358|240x320
Exactly my point.
Do you know what API MB smart uses?
I heard that you’re able reset via recovery, but they somehow make themselves the default Google account, so when you turn the phone back on, you need to sign in to their Google account to be able to use the phone, and can’t use it until you go back to them.
