See a detailed guide on getting started with ADB and installing eGate by @DonBot here: How to Install eGate Guide - Filters and MDMs - JTech Forums
- You will need a computer with the adb tool installed, and a usb cable to connect your phone to your computer. This tutorial should get you started with adb.
- Your phone will need to be able to connect over the internet to our licensing server. Either you need a SIM with a data plan or the phone needs to be connected to wifi.
- After purchasing, you will receive a message containing file download links for several apk files, along with a license key. Make sure to save the license key for the next step. Download the file named
egate.apk
. - Open the terminal app, and and run this command:
adb install -g "Downloads/egate.apk"
- In the same terminal run this command:
adb shell dpm set-device-owner com.oss.egate/.a
- Open the launcher and select the eGate icon to open it.
- Enter the license code in the license field and tap save. Ignore the dealer code field. If you see the app password screen appear, congratulations. Your license has been activated. If you see the Log In button again, that means that our licensing server could not be reached.
- Enter the password that will be used to password protect eGate. This password cannot be recovered, so make sure to store it in a safe place.
- You should now have arrived at the main screen, so configure eGate as you wish and exit the app.
- That’s it!
