hi there i have a cingular flip i want to filter it with adb
ADB stands for Android Debugging Bridge, only works for android
no theres hack from bannana hackers for kaios and i enabled usb debugging but was not able to connect it to my pc
I don’t know what the status adb support on the cingular flip, not all kaios devices support adb even if you can turn the setting on. In general, you should run far away the moment you see the word kaios.
Or you could look yourself for more info on kaios
Does anyone know any way of filtering KaiOS phones?
I think most people like staying far away to KaiOS phones.
I have like 10 of them which is why I just want to figure out how to filter them instead of throwing them out…
Tag definitely filters some KaiOS devices.
KaiOS is a partial android system, and doesn’t have all the features that filters typically depend on.
I never tried dumping firmware on a KaiOS device via mtkclient. I wonder if it could work.
Not all their phones are MTK. I was able to pull firmware from some of the Qcom ones, there are (some) firehoses available on bananahackers
Were you able to write modified firmware back and have it boot?
Throw them out and enjoy a less-stressful life…
actually, couldn’t get it to boot. im assuming theres some type of vbmeta type of security or a bootloader thing. Didn’t try too much
Yes, that is what I expected.
A post was split to a new topic: Kosher ROM for nokia
Custom ROM is probably the only way
Kaios is modified android so it should have debugging in there
There are some KaiOs on the list
4G Basic Phones_july.29.2024.pdf (1.8 MB)
