Kdroid MDM with flip phones
Does Kdroid work with any flip phones? Was it tested with any? Is it known NOT to work with any of them?
officially it’s supposed to work with every android device that has google services.
Many flip phones dont support google play services (same as “google services”?). Is there any reason not to try it? Could I brick it? Is it easy to undo if I have the password?
Let’s get this clear.
If you don’t have a backup of your device, then everything is a big risk.
Tomorrow or later I’ll create a guide how to readback a mtk device.
So you’ll be able to steal any software from any mtk phone. (Ah, and try any tutorial on any forums :blush:)
WwrMTK coming soon
I am not referring to personal info, I am referring to totally bricking the device…
Anyway, I tested the LG Exalt, it wont allow installation, due to it having an account already installed (Verizon Backup?). Testing the Kyocera DuraXV…
Totally don’t chap…
Could be. Factory reset…
Let us know :cowboy_hat_face:
can you give me a link to the mdm
com.kdroid.kiosk(0.8.1)-release.apk (4.8 MB)
Wrong one
That’s a different project
You’ll need the installer
https://mitmachim.top/post/718382
Whoops my bad
is this one free ?
The one he sent? No
does kdroid work with android auto?
Should be working…
What phone are you putting it on
Moto g play 24
How can I do it?
