Kyocera DuraXV Calendar Saga
Kyocera DuraXV E-4610 the calendar would open and freeze. I tried found 3 apps with the word calendar:
com.android.providers.calendar
com.android.calendar
com.kyocera.calendar.localaccount
Tried disabling them and the calendar wouldn’t open. I tried clearing the data of com.android.providers.calendar and now the calendar opened but you couldnt create an event because it says you need to add an account.(Goes to the add email account, not showing the phone/local account)
I tried uninstalling all 3 apps and pulling the apks from another device, uninstall worked, but when I tried to reinstall it gave me error:
adb: failed to install KyoceraCalendar.apk: Failure [INSTALL_FAILED_ALREADY_EXISTS: Attempt to re-install com.android.calendar without first uninstalling.]
Any ideas?
Try
adb shell cmd package install-existing <package_name>
Unknown command: install-existing
Sent DM
Here’s the solution:
First:
adb shell pm path
Get the path of the APK from the phone, then"
adb shell pm install -r --user 0 [path copied from above]
