Kyocera with T-Mobile
Are there any Kyocera phones that work with t mobile??
I think tello runs on t-mobile (please correct me if I’m wrong) and yesterday I got it working with the Kyocera e4810 also there are several AT&t Kyocera but they are not as good as the Verizon ones by far
So you are saying I should do E4810?
I had bad experience with the e4810 on tmobile even after setting the correct apns. you could try the dura xe epic not as good of a phone but works better with tmobile.
Again I used tello so first confirm what tello is running off of
Tello runs on T-Mobile
