That is a stupid answer sorry to be so blunt
Obviously I can google it and find out what it is
I want to know what people use it for
It generates UI/UX designs
Looks very AI generated
I think it looks beautiful and a lot nicer than their old UI.
They actually made it as a response to peoples complaints that ChatGPT looks nicer.
If you pay attention, you might notice that Geminiās new icons are a copy of the style of ChatGPTs icons.
I feel like the old UI rendered Markdown nicer
Nicer or more correctly?
Because Gemini 3.5 Flash seems to be not as good with exact formatting for MD.
Is Gemini 3.5 Flash better or Worse then gemini 3
- Better
- Worse
Nicer. Itās a UI thing not a model thing
How does it compare to claude design
Tbh I havenāt used either a ton (ironic considering that iām an alpha tester for stitch). Stitch released a ton of upgrades for Google I/O so I might start using it more often. One problem I had with it is that it doesnāt know your frontend code so itās a pain to implement it, but Iām pretty sure that theyāre testing a feature that lets you upload your codebase now.
Update email
Hi [altered],
Stitch just got a lot more collaborative.
To celebrate Google I/O, weāre rolling out a big update.
Here are the 5 major upgrades launching today (and one BIG bonus):
Streaming Generation: Stitch now streams its work straight to the canvas. No more waiting around for the ābig revealāāyou can actually see Stitch working and start steering it before the final product is done.
Start with your existing design: Building on the open-source DESIGN.md standard, Stitch can now generate your brandās design file by scanning your codebase, .fig files, or a live website.
In-place Edits: Want the agent to make a simple change? Easily replace an image, remove an element, or move sections of your screens without regenerating the whole design.
HTML-Native Canvas with Beautiful Motion: Stitch can create fluid motion on the canvas via scripts and shaders. The canvas also renders native HTML by default so you can immediately see hover states and effects.
Even more portability: Weāve added a big list of import and export tools to fit right into your workflow:
Upload a .fig file to extract a DESIGN.md.
One-click export to Lovable.
One-click export to Bolt.
One-click publishing to the web via Netlify (select any screen to get a live, āclaimableā URL instantly).
BONUS! Import and Sync with Code:
Weāre also announcing new skills that can be used inside Antigravity or any coding agent to import screens directly into Stitch via MCP. Make your vibe design edits visually inside the canvas, and then sync the changes right back to your codebase! Weāre excited to hear what you think of these new skills.
Watch the video or
Jump in and try the new features today!
Happy vibe designing,
Rustin from Stitch
