Making a TCL Read & Write
I want to delete the browser permanently. I have the commands to do it (su mount -o rw,remount / rm -r /system/app/Chromium) but I believe it’s not working because it’s read only.
I tried adb shell su /vendor/bin/write_protect 0 reboot a few times and it didn’t work.
Credits to @FliphoneBochur for those commands.
Those commands probably require root
I am rooted.
Insert a && between commands. Also, go to /proc/mounts and open as TXT, and check what can be mounted… sometimes you gotta go
mount -o remount,rw /
mount -o remount,rw /system
mount -o remount,rw /vendor
mount -o remount,rw /product
mount -o remount,rw /system_ext
And so on…
You need to disable write protect first with the command adb shell su -c /vendor/bin/write_protect 0 and then reboot i usually remove it with fx in system>app>chromium delete the whole chromium folder
That doesn’t help for tcl
I did that already but it did not work, I am still read only.
Are you getting an read only error?
My personal experience was that it would work to delete but it would return after a few minutes or a reboot. I had tried on close to 10 phones and was never able to delete it. I saw on the to do list on @netroscott 's page (about a year ago) was to figure out why some phones won’t remount.
you are right it did delete but it returned after reboot, i was able to delete it on a different phone a while back but its not working on this one.
Check his page
Try it in recovery. I remember having this issue once, if I recall correctly using neutrons recovery image it worked
Where do I find his recovery?
Didn’t work for me in recovery.
Whats the step’s? fastboot flash recovery... and then?
Then use adb through recovery like before
So after flashing it I should put in adb shell su /vendor/bin/write_protect 0 without rebooting first?
This is what I got when doing it in neutrons recovery:
C:\Users\\OneDrive\Desktop\ADB Latest>adb shell
$ su
# /vendor/bin/write_protect 0
/system/bin/sh: /vendor/bin/write_protect: inaccessible or not found
When I rebooted I still had my browser.
it should be set to 0 already anyway.
Is there any reason I should flash the stock recovery back on?
Is there any way to delete the browser permanently without read write permission? (Maybe a third party app…)
