Dialing with Google Voice on a Flip Phone
This method allows you to dial through Google Voice on a flip phone. It's very "Yeshivish" and requires a bit of a workaround. It does take about 20 extra seconds to dial, but it works reliably and gets the job done.
Dialing Format
Use the following structure when creating the contact:
YourGV#, *YourPIN#, 2, NumberToCall#
Example
- Google Voice Number: 518-455-2800
- GV PIN: 745689
- Number to Dial: 202-456-1111
Final dialed contact number:
5184552800,*745689#,2,2024561111#
Important: The commas (,) insert a 2-second pause. These are crucial and must be included exactly as shown.
Pro Tip: Save this entire sequence as a contact. When you call it, your phone will follow the full Google Voice flow automatically.
Bulk Editing Contacts
To avoid editing each contact manually, follow this process:
- Export your phone's contacts as a VCard (.vcf).
- Import that VCard file into Google Contacts.
- Export from Google Contacts as a Google CSV.
- Open the CSV in Google Sheets and bulk-edit the phone number column.
Modify numbers in the format below:
5184552800p*745689#p2p2024561111#
Note: Replace each comma (,) with a lowercase "p". This is how pauses are encoded in CSV contacts for flip phones. - Download the edited file as a .CSV.
- Re-upload the file to Google Contacts. This is mandatory. Skipping this will make your phone ignore the changes.
- Download the updated contacts from Google Contacts and transfer them back to your phone.
You're all set! Enjoy using Google Voice on your flip phone.
