Message Plus On A Kyocera DuraXV Extreme Plus E4811
hi everyone
i was able to get message plus flip phone version working on the kyocera dura xv e4810 but i cant get it to work on the kyocera e4811 any solutions?
Just curious does it work exactly like on the exalt and cadence or you need the mouse for some stuff?
not sure what you mean
Does it function perfectly with the d-pad or you need the mouse for some things?
Regarding what?
like to scroll through all the threads do u need mouse?
Inside a thread can you scroll up with d-pad?
I’m sorry I really do not understand what you’re trying to tell me
I am sorry for not being clear,
When you use message plus on the exalt it works very well with the d-pad of the phone. Because it was designed for a non touch phone it works well.
My question is, when you use message plus on the 4810 does it work well with the d-pad or you have to activate a mouse sometimes like to press certain buttons.
Of course if you install the app that they use on the flip phones
@sams-club Did you get the apk from a different flip phone?
If yes, can you post the apk, I want to try it on my TCL.
Thanks
It’s not going to work on a TCL because TracFone blocks it. it wouldn’t work on most other phones as well besides for the kyoceras
I had message plus running on it in the past. I just want to try the flip phone version out cause it will be awesome using it with the d-pad.
Maybe the web version or the regular version might work but I don’t think the flip phone version is going to work.
If you have telegram I can send them to you
I am not looking to use the message plus features (like chats…) I just want the app. You think that won’t work either?
I don’t think so I can send them to you if you have telegram
Can you email them through google drive?
I don’t really have time to download and reupload but if you look on the a4f forums you might find them
ok no problem thanks anyway
If you have a friend on telegram that would be willing to do that for you let me know I can send it to him/her
