My Laptop Crashed
I was using my Computer and then the screen went black. I have a warrenty but I rather try revive. It will not turn on. Any ideas?
What are the specs of your computer?
Integrated or dedicated GPU?
What is that? Where do I check what it is?
What info do you want? Its an HP Intel core i5.
Ah, integrated. Let me think
Laptop or desktop
Laptop
Does the HDMI output work?
Edit
I see you said it’s not turning on
Let me check
Ya nothing works lights etc
To rule out dead battery, try turning on while plugged in?
Yes worked thanks. Its funny because right before it turned off it was seven percent now 6
Lol enjoy
Charge to 100 and make sure it drains normally
