Tested the shell script at first I get an error no adb device, then it crashed.
Yeah I put it in experimental for a reason, not asking you to try that until I do.
Pretend it’s not there
Wow I love the idea!! (Should be it’s own thread) I’ll try soon
Sorry for being lazy but I have no patience reading through all the topics about the qin to find the answer.
Does flashing the US bands on the qin make it not work in Israel?
Once it’s good
I believe it won’t work in Israel.
Thanks @The-curious. I just spoke to him and he said it won’t work with 4g in Israel. (The band listed on the website if the f30 also only lists American LTE bands)
Thanks @kosherboy
@ars18 the ROM you made for the qin f21 works with the original nvram nvdata and nvcnfg?
Do you need the original partitions?
No. I didn’t flash yet anything
6.1.3 has US
He can replace the partitions of the bands with Israeli ones.
@farrict is very knowledgeable about all things Israeli and American bands.
Ask him anything you need
He loves to help…
Yeah I know. The question is if you modified the system image or anything else that would cause issues if I would flash your entire image (all partitions) and then just flash back original nv partitions so that it works on Israel
I did it it worked no problem
Can anyone help me change an IMEI number on a QIN phone?
I’m using SN writer tool and for some reason it doesn’t work It fails every time
What bands you flashing ?
He’s not flashing bands now. That was done already. He’s just trying to change the imei.
you have to be on a 1.1.1 rom or some rom based off of 1.1.1 also you can try using @ars18 tool though i cant find it anymore maybe he took it down
You mean you have to be on stock, or stock based, which 1.1.1 is…
