Qin F21 Pro Topic
Yes but you will have root
Ok thanks
Hi I’m new to this type of thing I tried using adb install on the f30 and just says not allowed, is there any way to get around it?
The Qin F30 is pre-filtered and can not be used to install anything via ADB.
6 posts were split to a new topic: How can I Flash US Bands on Qin F21 Pro Without TWRP
12 posts were split to a new topic: Error Flashing Qin F21 Pro Using SP Flash Tool
I found this, may be useful to many
Can someone please provide a link to AliExpress or Alibaba where I can buy F21 that’s able to unlock the bootloader?
Can Google Play Disservices be added to the non-Google versions of the Quin?
And do the ones labeled ‘Global version’ work in the US without flashing bands?
You still have to flash US bands.
Anyone have the best AliExpress link to order the qin f21
hi i kind of new to this but is there a way to have google play/gp services without rooting it like on the xda guide (i have a qin f21 with an unlocked bootloader)
also i followed the root guide on the xda forum and completed it but the twrp recovery that comes with it whenever i boot into recovery i cant get out of it even when i reboot syste it just goes back to recovery. so does anyone have a differnt twrp for qin f21 32gb
thanks
If you followed it it’s supposed to work
Make sure you do everything right
Does anyone know how to certify play services without all the magisk modules so i could add it to a rom?
does any one have experience with MTK client GUI?
im trying to install it and i can’t find a good link
Care to explain?
many apps on qin f21 like myzmanim or gmail wont work without the play store installed (i flashed the gapps zip from twrp and the i deleted the play store apk “phonesky.apk” not sure if that is a good method) is there a way to get these app working with the real google play services or should i try one of the methods listed here
I’m not sure if this is helpful but I did get Play services to work by using the Magisk model on a TCL flip 2 so it may work as well on the qin.
I would do Microg there is a Magisk module (don’t know twrp) for this which by default installs a fake version of play store because play store IS needed for play for play services.
