Regarding OldMDM (Comments)
It does. which android version are you using?
I wasn’t sure if you offered the hotspot block as you were asking for each individual app to block specific applications. Was just pointing out that his Spreadsheet doesn’t include hot spot blocking Or the Packaging for hot spot.
ah
is this a one time set and forget? or can you sign in and out to make config changes?
for you i’ll let you sign out - if you install now and request for the next 30 mintues
If one does install this app, whats the best way to reach out to request a paid unlock code if needed? You set up a website? Or pm?
If the kyocera and LG devices have different package names, assuming you’re mdm has all possible options preloaded to disable needed applications? And not a different filter for different devices?
If I have already installed a package before installing the mdm will my app got kicked off when I am installing the mdm?
No.
It doesn’t block apps that are already installed.
Yes
is this still active need it for kyocera cadence s2720?
@TripleU
i guess… try it
where do i download from?
Do you still provide support for it?
no idea. no.
the link above expired and doesnt exist your google drive
If you’re referring to the same OLD MDM you can access it on @DonBot MdM Installer
Mesnan Filter Solutions
And it works on cadence?
Dunno, never tried it on the Cadence.
How do you plan on removing it if it doesn’t offer support to unlock, unless it’s set and forget?
how is it called
i dont see any filter named oldmdm
