I tried a couple devices, never got more than basic.
there is a way to get hands free assistant app working on the qin f21 without root?
anyone knows??
Which app exactly
i tried Alexa
there is a better one??
hey google don’t work
What does it mean it doesn’t work ? what does it tell you does it give you a error?
it works only when i am in the app
in by google assistant it comes up by the hey google feature that is not supported on this device
still waiting… guess i have to call customer support
What does it say trying to verify ?
yup. said that for a week
Then call them
I flashed 6.1.3 yesterday and RCS worked perfectly.
How do I get the play protect certificate to work I tried updating tricky store and play integrity and it’s not working
It doesn’t work anymore you cannot get your device Play store certified
What carrier? New phone? stock 613 imei or your own?
Us mobile warp. Not a new phone. Stock imei.
I did have RCS registered on this number from a different phone.
Also it was saying verifying for a while till I went into more settings and pressed one of the options there (can’t remember which one) and after a reboot it worked.
Did you test with more than one sim? Maybe something’s off with that specific number…
I have T-Mobile and RCS is connected with 6.1.3 ROM
interesting, i am using warp as well and had issues even with a brand new freshly flashed device. I will try again!
Set this keybox in tricky store (tricky does not currently have any available valid keyboxes):
keybox.xml.zip (7.0 KB)
@sh7411usa (or anyone else) lemme know
Nope. Just Basic
