Rooted Boot Image for TCL (KEFS and KEKA)
can you be a bit more specific? so the issue is currently is that the command sed… failed and corrupted the build.prop file which is necessary for booting. now that its already corrupted, will the new command work?
also, not sure where to run it from. fastboot still works, so you’re suggesting I should flash that image as what? is it compatible with my model? and then what do I do?
thanks so much for taking your time to help!!
If he was able to install an app when Bluetoothing doesn’t that mean he can install apps?
Yes through the file manager it doesn’t work i would recommend using fx nothing fancy and get to adb using the adbio app
To make things simpler, just flash this stock super back. Will take down from drive soon so lmk when you download it
Is this for the keka or 4058g?
keka
Hi everyone,
I am out of my depth here. I just got a TCL flip 2 and my software version is QK6V, a canadian phone. I don’t see anything about these software versions. the DEBUG dialcode is deactivated on this phone, does that mean I can follow instructions for KEKA phones?
walkingcak3 did you ever get your canadian tcl flip jailbroken?
