Rooting Sonim Phones
On the Xp3900:
  • Android 11
  • OEM unlocking in developer options
  • No unlocking command works in fastboot
Same thing as Kyocera, got it.
They may have neutered it, or changed the command.
If you’ve got patience, you can check the xp3800 firmware dump, and analyze the bl partition. If they changed the commands, you MIGHT be able to see, and it MIGHT be the same for the 3900.
Rooted, Untested.
Where u get this from
No Further Questions GIFs - Find & Share on GIPHY
Mysterious
can you please get also for the xp5800?
I raise you - stock, untested. Lol
ye ye
And how am I supposed to flash it?
With the firehose we don’t have, duh. Easy peasy
.elf file
Responds to ABSOLUTELY nothing?
What about fastboot getvar unlocked
Anyone has any experience with or knows anything about reverse engineering Windows software?
You have a repair tool for sonim or something?
(firehose)
Noice, that completely went over my head, I was looking for an mbn.
mbn and elf is the same idea
So this is the same as prog_emmc_xxxxxxxx.mbn?
Same use?
yes, i think. what does chatgpt say?
