Small Questions That Don't Deserve Their Own Thread
Is it possible to PM a GitHub user?
I am using Whatsapp on a TCL Flip 2. Every time I get a message the notification comes up twice. Anyone has any ideas why that would be.
In the past I ran into trouble for having too much apps on my phone. I was wondering, if I disable an app is that as good as not having it regarding everything besides the actual storage space it uses?
yes, but do a logcat to see which apps are running into problems / draining RAM
So it won’t use any ram being disabled?
How do I ā€œdo a logcatā€?
yes
ADB logat
What now, things just keep popping up on adb?
adb logcat -e error crash unable
What is a logcat
Is there a way to mod an app to disable viewing pictures?
basically tells you everything happening on the phone
Anyone know of a text editor that I can use to format my posts more easily?
Chat gpt or co pilot or deepseek😜
AI is great for formatting stam a post, not for when I want to put a table in my post, or want to format it myself.
But AI is still great for recommending an app to use (it recommended Markor, I’ll post if its a good app).
And btw, I can’t use the ChatGPT app, it needs Google Spy Services.
Deepseek can make a table
I’m not giving the Chinese government my data.
Bad enough that I have to give it to Google and Microsoft.
Anyone knows of any companies running deepseek on their own servers?
Perplexity does, and even made their own version of the model (Deepseek 1776, which is also open source) with the Chinese censorship removed, but unlimited usage is locked behind a paywall.
Grammarly extension works inline
Any recommendations for an email app with good d-pad compatibility?
I’m currently using Outlook, which has great d-pad compatibility (most of Microsoft’s bloatware has great d-pad compatibility, including OneDrive and GroupMe), but its a very heavy app, uses a lot of memory, and every time I open it it starts all Microsoft apps that I have installed.
The light version doesn’t have any d-pad compatibility, and has an annoying layout.
Aquamail
In the end I didn’t like Markor, I ended up finding a different app that I liked a lot better, it lets me see in real time what the post will end up looking like with the formatting, see my post over here for more info.
