Sonim XP3800 General Question and Help
Is the sonim built in mdm a reliable filter?
explain
I never really played with the sonim phones. I see that they have a built in mdm. Is that something that can reliably filter it? As in block Internet in all apps, APK installation, maybe video as well? And can’t be reset?
it could block reset its not really an mdm its more of an app so… and cant block video it does come with a verizon mdm but not sure what that is doing besides getting in my way…
That’s the same as sonim scout?
Sonim scout is not reliable
Does not block reset via recovery
correct
Do you mean the safe guard or their cloud?
The Sonim Scout doesn’t seem very reliable.
I set it to block an app, and sometimes there is be some time between when the app is opened and when Scout blocks it.
their cloud is very reliable its disabling the app there’s only one loophole but i don’t think somebody will figure it out as you spose to preform a factory data reset and then do some settings it shouldn’t sync
There is a very easy way to bypass sonim safeguard if scout is not restricted
And even then you still have reset via recovery
that’s what i am saying that using https://sonimcloud.com/ is better and safer
i cant log in it
do you have an account with them?
I tried it just never worked what business did u use
I am using it for the kiosk mode and for the disable application and a few more if you have any problems try looking there videos @sonim university on youtube.com
or ask me I’ll be glad to help you
Ok I tried resetting via recovery and all the settings started the same…
I dont think the issue is with specifically the package installer app cuz it wont work from a terminal emulator either. I also tried installing a few different installer apps but none worked. Then i realized that the pesmission that all those installers come with request_install_packages was revoked and when i tried granting it via adb it said something like its not a permission type that can be changed. It looks like sonim worked very hard to make it impossible or at least very hard. I have no clue why. The funny thing ĂŹs that it still works fine to install apps via adb
Safeguard isnt safe. Ive had more then once that safeguard just stopped working and all apps were unlocked till i reactivate safeguard.
If an app doesn’t have request_install_packages permission, then when it tries installing an app the package installer won’t open.
Thats not what happens on the Sonims.
If you try opening an APK, the package installer opens, and then says app not installed, which means the package installer is blocking the installation.
If you use the same apps to install an app signed by Sonim, like the Zello app for Sonim phones, it will install.
If those apps didn’t have request_install_packages permission, that wouldn’t work.
