Is there a way to have Spotify without any images being displayed?
This will be very beneficial for the inappropriate images that are on non-Jewish music covers that randomly pop up even if you don’t listen to non Jewish music on Spotify
I was always wondering this. Spotify there Is hacked versions plus its cheaper than 24six.
@Tripleu should know how to edit the apk.
This was done in the past I’ve seen it in Israel
(Underated. The Israelis know how to mod)
MB smart can block all pictures in Spotify.
And it’s terrible the app crashes with mb smart bc it removes each individual picture so it over works the phone
There should be a simple way just like removing statuses and channels on whatsapp
Not true. MB smart block Spotify from being able to receive the picture data by blocking it through their VPN.
I have never had a problem with the app being slow.
Look for the link in the smali and damage it… that’s how the Israeli’s do it.
This is my first time editing a smaili file… there are tons of them, which one?
How can ahold of the Israeli version?
chatgpt can be really helpful
When I tried using it to build apps I kept running into errors resulting in a big waste of time.
I know that it can be done via the host file
Do you know which domains to block?
You have to use it as an assistant or be very patient with it. its hard to get it to do everything
