Stop Hotspot Throttling: How to get around your carriers hotspot limitations
Sounds like you haven’t used vpn’s.
Download a free VPN app, i would suggest proton vpn, turn it on, then use that app with the instructions for the hotspot.
on my laptop or on my phone?
Phone.
VPN hotspot app will allow you to share the VPN with your hotspot.
I tried pulling from play store and the app crashed.
Anybody have the app?
which device are you using?
TCL flip 2
Its probably because I pulled it. It happens often when I pull
ill pm you the apk
Thanks downloaded and made account. What do I do on app to set up vpn?
Thanks
Tap the blue “connect” button wait till it connects, then use and follow instructions for the hotspot app
  1. When you say that it doesn’t use my hotspot data, that means that it is using my normal data? 2. Is there any reason why the app is working but it isn’t showing up on any device whether I’m the WiFi direct or just Stam WiFi?
  1. It will block your carrier from knowing that you are using hotspot
  2. Need more info on what you’ve done so far
Yes.
If its happening I’d assume that there’s a reason.
I don’t know why that’s happening.
Did you go through its behaviour and info tab?
Where is that?
  1. Does that mean that if I only pay for 15 gb (theoretically) then now I have unlimited, using this? 2. I followed all instructions in the app, and at first it showed up on a 24six but wasn’t letting me connect was saying wrong password or something like that. So I tapped restart turned it off then on and then wasn’t showing up anywhere.
Absolutely not. It uses regular data understandably.
Your sure you turned on a vpn, and ur device is rooted?
I meant if i only have 15 gb hotspot but unlimited data
and my device has to be rooted and needs a vpn? i thought that the point of the app was that it doesnt need to be rooted or use vpn?
He’s not using
this app,
he’s using
this app.
The first app, vpn hotspot, needs vpn and root, the second app, TetherFi, doesn’t.
