I cant upload the screen record not sure why but the overlay does pop us just doesn’t click
I’m not sure how to say this, but…
I can’t install it because I need a computer to install it with adb.
I’m saying that it should be possible to make a virtual mouse app thats basically an on-device scrcpy, working through Shizuku.
I thought you had a way to install without a computer with shizuku
One last test application for today if you could try this, same idea of removing the overlay then clicking:
app-debug.apk (9.9 MB)
If this doesn’t work, I’ll look into using Shizuku to support Android 11.
Something’s messed up with my phone, and it doesn’t work anymore.
The notification shade doesn’t open.
Going to do a factory reset, but for that I need a computer to make an adb backup.
Ah I see what you mean. Looks pretty interesting and might offer another option to inject inputs. This is next on my to do list.
You cant use the backup and restore app
It doesn’t backup app data.
What’s the command to backup all data
Android 11 has a bug in it that doesn’t allow virtual mouse apps to work.
It was fixed in Android 12, but there isn’t any mouse app that works reliably on Android 11.
There’s a fork of MATVT for the Sonim xp3900 on GitHub, with very mixed reviews, ranging from ‘works somewhat’ to ‘doesn’t work’.
There’s a thread about this on App4flip.
Why does the browser mouse work normally?
Because its built that exactly what the mouse module for the tcl is but i don’t think there is anything to do about the sonim you could try the app switchboard it won’t be as good as a mouse but it might do the job
What is this app?
