I already made a new one a while ago. This one’s dpi isn’t automatically adjusted. I’ll try to get that done soon.
New Waze 4 Flip.apk (98.2 MB)
Thanks. For some reason the link isn’t working.
Oops! That page doesn’t exist or is private.
Just tried on both LG Exalt and Kyocera DuraXV E4610, here are both errors respectively…:
Failure [INSTALL_FAILED_OLDER_SDK]
and
Failure [INSTALL_FAILED_OLDER_SDK: Failed parse during installPackageLI: /data/app/vmdl1990793083.tmp/base.apk (at Binary XML file line #9): Requires newer sdk version #26 (current version is #25)]
You can try using the old version and zygisk detach
thanks it worked. looking forward for updated version with better resolution
On which phone?
it doesnt install on a exalt
what is zygisk detach
It takes a app and hides it from the play store updater
And when does such a thing come in handy, just turn off auto-update?
revanced etc.
how can i do it and does it work for a flip phone
It’s a magisk module
tcl flip
It is very big is there a way to adjust the dpi of the app to fit my screen?
You looking to adjust the dpi specifically in the app or on the whole phone?
Just app
The app
