What is eGate software?
I’m trying to use eGate on a galaxy S23, I wasn’t able to set the device owner with a ADB I did it through settings, but now after I set the password and then enter the password, the app automatically closes and says there is a bug? Please help
It doesnt work to set it through the settings app. You can only set device admin through settings, not device owner. What problem did you run into with adb?
I am planning on blocking everything I need to with e-gate then changing the password to something I won’t remember but I just want to make sure first that the apps I use will stay updated via play store. Is that the case? I do have it set to auto-update in the play store settings.
Which blocking function were you planning to use for the play store?
I recommend someone should know the code in case you need to adjust things in the long run.
Sorry not blocking the play store. Just selecting what apps I want hidden/blacklisted
Yes, your apps will stay updated.
An Egate license means you can download on 1 device?
Or on several devices?**
One device.
You pay per a device. It’s a one time payment.
*why would you chose Egate over Triple U MDM,
Price wise
Egate: $40
Triple U: $10
Random question,
There is some person filtering, with egate for $35 make sense?
Is there some bulk license or something?
Ask @FlipAdmin about becoming a reseller.
Thank!
At least one solid difference between Egate and Triple U!
Price Wise
Protection wise
Reseller licenses are $15 each.
i installed on galaxy a16 and i tried logging in a few min later all it says is incorrect password, it is 100% the correct password i took an image of it. i tried hitting reset link but nothing happens. please help!!
Its case sensitive, did you ensure that
yes but i tried both ways still incorrect also i cant reset password even though i put in email the reset button doesnt respond
The egate link says out of stock eGate - Payhip, is there a new link im missing?
You can buy a license in the app as part of the install process.
I’m using it on a Qin phone, I’m up to the screen that requires me to set the device admin. I did it through ADB and it’s still not working?
Can you show me exactly what adb commands you ran?
