More info?
Write detailed in the submission if you can
For example instead of “todah” it’s toidu…
Is possible to filter certain podcasts like female or uncensored
Yes for women, but it’s female content, not if there is a woman speaking.
You can block all.
Ummmm… Send the links please :slight_smile:
How do I block a channel of woman podcast
Again, it’s not specific podcasts you can block. You can block female marked podcasts by not showing female in onboarding or in content settings.
This is taking effect on podcast
Can’t help you if you don’t elaborate in your messages. Don’t know what you are saying.
These podcasts are not included in disable female.
For me it sounds that disable female content is only taking effect on music not the podcast :melting_face:
I’ll make it clearer
Thanks for those very fast responses. hope you understand :+1:
Those microphone botton on home screen is made to search a song by signing? For me it doesn’t sound that it’s working.
I tried it a few times and it didn’t found any matches, even zemer has the song.
But when I tried it on Google and in YT music it cached the song I’m singing
Promot chasidish content my use a fix up (if possible similar to zing home screen recommendations).
If possible to add some features from the SK music platform, like hide Israeli artists, only chasidish artists, shiurim form Torah anytime, would be great!
It’s a must to say ZEMER is the best Jewish streaming app, even the UI, maybe also batter then YT music :partying_face:
By recognizing songs. Singing not really accurate.
Removed from nightly, never worked.
Nothing from zing will be added.
Use the genres to filter to whatever you want.
YouTube music and YouTube only
Thanks :slight_smile: please share with others
@ars18 :jtechforums: - instead of checking if there is lycrics on that song the icon should be greys out if there is no lycrics-
It has to check to know…
Update to latest nightly if you want all lyrics available
Is worth to use nightly, or has a lot of bugs.
How do I filter the genres.
Please explain search by singing problem.
When is the respect the next update
yes, since its uses date, there should be a setting that it Auto Check if lycrics are avalible..
It does… :slight_smile:
And also, latest nightly fetches result when you start playing, not only when clicking the button. Prefetch.
More and more being added.
Over 15k now.
Make them need more! The whole point of a GPU is parallelization…
You have no idea… :joy:
And still it’s only 8gb vram
Right it’s testing a new model I may switch too
