What is your Goal before you start Advertising?
I get unknown error trying to play music after using for about a week. I had the same issue with other YouTube music clients like metrolist innertune and outertune
The names on videos do not display proper
Just tried now. You are right.
Don’t think there’s a “fix”. Will probably have to remove.
I hate to say it, but one day this entire app will stop working. Hopefully in a long time from now.
I didn’t plan on advertising. Why would I?
Thanks for the report.
Something to do with screen size probably. Maybe not
Do you have issues playing media with no login?
  • Yes
  • No
0 voters
Do you have issues playing media with Google login?
  • Yes
  • No
0 voters
Do you have issues playing media with anonymous login?
  • Yes
  • No
0 voters
for me the google login is a hit or miss, it’ll usually work but randomly give me an error
I fixed it - in next update
Why is that so?
I’m having a problem with downloads.
It doesn’t download the full track, and then when playing it, it stops in the middle.
I haven’t been able to get tracks that the downloaded was corrupted working in Zemer, even after deleting the download, and clearing Zemer’s cache.
I can’t reproduce. Just tried and it worked fine to play the whole song.
Anyone else?
It only happens if you download when it didn’t load the full song yet.
So if you already played most of the song, or have song offloading enabled and you started playing the song, the download will be fine.
Also, what’s very weird is that the downloaded files play without problems in other players.
I think I might know the fix. I’ll look into it
Please let me know of any issues. Nervous about the playlists… but I tested.
Just to be clear, you are downloading a song, and when playing from downloads on Zemer you have this issue, but not from anywhere else.
Confirm plz
Actually, it looks like it’s not exactly like that.
I now tried playing in File Manager +, and had problems, only Musicolet didn’t have any problems, I guess it’s decoder is more robust.
When I added bento for metadata things got a bit more complicated
Plays fine on Zemer though?
No.
I just gave it another try with a few songs, when I downloaded from the home screen, it didn’t have any problems, when I downloaded from the playback screen, it had problems.
