I don’t see any options
Just this, doing need options.
Actually just have to play a song. Image cache
Beta update coming soon… Nice new features.
Will you test for me?
  • Yes
  • No
0 voters
v25 beta
Audio & Video Quality
  • Quality selector now on player screen - tap to choose bitrate
  • High-quality OPUS audio (up to 280kbps) and 1080p+ video (Google login only), up to highest available for video.
  • Anonymous users can still select quality, but with fewer options
Downloads
  • Choose specific quality when downloading audio/video
  • Swap downloads for higher/lower quality/format
Optimization and bug fixes
  • Attempt playback/download fixes for <Android 11
  • Touching middle of screen on video player toggles controls instead of pause/play
  • Music downloads now fully removed when pressing “remove download”
  • Added new authenticated client - TVHTML5 (when logged in with Google, not anon.)
Screenshots
AFTER INSTALLING THE APP, PLEASE LOGIN AND FORCE STOP ONCE THEN REOPEN.
I’ll work this out in the release.
Download
https://github.com/alltechdev/Zemer/raw/refs/heads/main/v25_beta_app-release.apk
PLEASE REPORT BUGS, I NEED TO BE CONFIDENT BEFORE RELEASE.
Just played with it a bit on a qin. Seems amazing! Thanks!! Didn’t find any bugs so far. I’ll let you know if I do.
Try all new features plz
With Google login
Could you make a option to download mp3 format
When I search some songs it only comes up as a video not a song u could try “keep going” it’s Lipa and mordy shapps and only the video shows up
Maybe but probably not. Use any converter. Also, any standard music app should be able to play these.
Only shows up if it’s available
I didn’t use the other versions in a while (wasn’t working on my old phone) so not sure what’s new but I tested everything you mentioned here and no issue so far
Sonim, or f25?
Can you try both?
I meant f25. I just tried on Sonim but on the Sonim it still has that issue where nothing plays at all.
:eyes:
On all three engines logged in with Google
Engines?
Phone?
Android version?
please insert songs from ישיבת רמת גן, ישיבת חולון וגם אמנים אחרים שקשורים לזאנר הדתי ציוני. תודה רבה!
YouTube Music Channel links plz
Randomly when I’m playing a song I get a unknown error
Anonymous or google
