25 is test, some things broke in there. Clearing data should have helped. Uninstall and reinstall.
Cannot reproduce the issue sorry
I am having the same issue. Logged in never works as annonamus is sometimes works
Have you tried the new build? Can you clear data, uninstall, then reinstall from the link below and let me know?
https://github.com/ZemerTeam/zemer-app/actions/runs/23100021397/artifacts/5928079952
That link is not found
You need to sign into GitHub first
Now this
Honestly not sure. I just tried again 3 times, with Google and anonymous. Working fine.
Did you clear data, uninstall, THEN reinstall?
Yes did that. Thought it’s working as annonamus now as well but not when signed in
Phone?
Android version?
One last thing to try to possibly narrow things down. Log in with Google, force stop the app, reopen, and see if it plays. If that’s the issue I can fix.
A Japanese phone Freetel Mode 1 Android 13
Heard of those.
I have no idea how to help. Sorry.
Tried the force stop. No luck. Thanks though
If you are fine with adb you can remind me tomorrow or Tuesday for a debug build and we can try and see what’s going on.
Remind me, I 100 percent will forget.
I tried logging in with Google then force stop on a qin still Didn’t help
this is what happens
Can you add the listen and it tells the song feature like metrolist has?
I want to do alot of things for zemer, but I stopped for now. It’s not a simple copy paste, everything must be filtered.
I need a break, just fixes that are 100 percent necessary.
There are no pull requests, very few people testing, and features break on so many different devices…
I’m tired.
Could I send me a older version to see if it works
