American Lasting Flip Phones in Israel
What flip phones that work in America work in Israel as well?
I need one that lasts, not like a TCL or Alcatel
Basically anything that works in USA should work fine in Israel…
qin and fig
What are you looking to use the phone for call only, text as well, or data as well.
Does unlocking the bands on the qin f21 make it better or worse for Israel?
Worse
at יא ×˜×‘×Ŗ תשפ"ו, support for 2/3 G in IL stooped.
Because this, you need 4G phone that support VOLTE.
4G IL bands: 1,3,5,7,28
Qin F21PRO doesn’t support VOLTE in IL.
Cat S22 flip supported f4G in IL, but I’m not sure about VOLTE, I havn’t right now a SIM card that supported VOLTE for testing.
Did you mean that soon they will stop 3g? Would that mean the tcl would no longer work since it had the bands to only work as a 3g?
Yes.
I guess that would mean the Qins will stop working too
How about if you put on us bands
Do you know what the problem is with the TCL that it only works as an 3g? If the only problem is that its missing volte than the moudle that enables WiFi calling also enables volte.
TCL Flip 2?
don’t support Israeli 4G bands.
Is there a to flash them?
IDK
I hope…
