eGate for Kosher GPS
I would like to purchase the egate mdm to use to lock down a android device and only have Waze & Google maps.
1 Can i block waze ads?
2 Will the apps update if play store is locked?
Can someone create a guide for that? and maybe also recommend where i can buy a good fast phone for a good price?
for that you need Kdroid.
I might want to add more apps in the future
and i dont think that kdroid supports google maps
Kdroid allows Waze?
Yes but not google maps
Block ads - I think that you can use AdAway DNS
Update apps - you can use Aurora upadter
Thank you
Can anyone clarify if the apps will still update in background when play store is blocked?
im also looking for a way to block the google maps images
With root or without?
Do you know what the URLโ€™s are for Google Maps pictures?
without root
not sure
I was supposed to release a guide (for rooted phone of course). Just got a little busy
Update with this
Thank you!
it seems that with aurora and dns to block waze ads and google maps we can have it done.
I would appreciate if someone can make a full guide in how to make a kosher GPS, i would probably buy a few licenses to create the device for family members
I create only waze ROM for Galaxy a06 SM-A065F.
But, IDK if this device work in USA.
Of course, flashing the ROM is paid.
Will aurora store updater still work if apk installation is blocked?
yes
Donโ€™t updaters download the new apk and install it? If so how can it update with apk install disabled?
root
With root i can use many apps to update i am talking about non root.
Some thing like I will disable unknown sources and make this app store like play store so it can install apps
If someone would make an aurora updater that uses Dhizuku, it would be able to update apps automatically without root.
