Fastboot to SP Flash Tool
I’m stuck in fastboot mode on my Tiq M5. I want to reset to stock, but the bootloader is locked, preventing me from using fastboot to update the software. How can I flash the firmware via SP flash tool? I’ve tried holding down the power button while the phone is plugged in, which restarted it, but when I set SP flash to download mode, it won’t proceed, it just returns to fastboot mode
Format + Download in sp flash tool
I can do that while it’s on fastboot mode or as I’m turning it off?
this.
It’s not working
Just keeps restarting into fastboot mode
after format and download? which ROM are you using???
Im trying to flash the latest TIQ ROM.
it should work. no question about it.
Well it doesn’t
Want a video?
yes
I held down the back button while restarting and it worked
Thx
