Kyocera Phones Delayed MMS
Ok this may have been discussed, but I am hoping to get to the bottom of it this time.
Kyocera phones with message+ (both the Cadence and E4610 are affected).
The phones can work normally for a while, and then all of the sudden struggle with sending MMS normally They will say sending, and not be delivered for anywhere between half hour to over 2 hours… Doesn’t seem to be a service issue as using another sim doesn’t fix it. As far as I can tell, a factory reset does fix it, question is if it can be fixed with less-drastic measures…
Did you test them with other messaging apps?
No. What do you recommend that is modified for these phones, and also works decently with D-pad?
I’m not saying that you should be using a different app, I’m saying that the first step to figuring out what the problem is figuring out if its a problem with the rom or message+.
What needs to be modified?
The not-allowed-to-be-disclosed modification to allow the apps to be installed on flip phones that block regular apk’s from being installed. Basically back to the root of where the whole apps4flip began…
Yes good idea, just want to try with something usable…
K, will mod and post.
had this issue just allow unrestricted background data for the message+ app
Try this
Is that the version that lets you start a conversation using a d-pad?
Thanks. How is that done?
Yes
use button-mapper to open apps then go to message+ and data
Tried this, it didnt work…
Going to try google messages next…
