Readers add, especially @chatzie that stubs did with them for Android 13.
I tried on more than one and it didn’t always work. Even if it did, it would result in Android Auto working slow…
But PM suspend is like the mdm does it, so it’s the best.
But again, stubs may work as some of the users said.
Go ahead and try, in worst case, this is just another method…
I use this method already for a while with adb on my Samsung galaxy a15 but if you uninstall updates from Google and then Re update it will get unsuspended
So maybe that’s it. you need root for it. i didn’t try without it so yes…
root - not davka as in SU, but run by sepolicy or anything with higher permissions than 1000 - like an MDM
So I get this when trying to disable Exception occurred while executing 'disable': java.lang.SecurityException: Shell cannot change component state for com.android.quicksearchbox/null to 2
