Sonim XP3800 General Question and Help
anyone with the app updater for the sonim xp3800 in a apk format?
Hope this helps you
SCOUT App Updater_13.1.20.02_APKPure.apk (2.6 MB)
Is anyone able to install apps on the sonim through the file manger?
it don’t spouse to work only apps that comes with the phone like there scot and etc.
does this work on any phone?
i think its not the original one because it says there was a problem parsing the package
Sonim purposely blocks installing apps that they haven’t approved, officially as a security feature.
It has nothing to do with the file manager, as the file manager opens apps with the package installer. The problem is the package installer, which is customized to only install apps with their signature.
I tried signing apps a bunch of different ways to get them to install without adb, including signing an app with Sonim’s signature from Zello, nothing worked.
The only thing that might work that I haven’t tried yet is to replace the package installer with a package installer from another phone, or with the package installer from an older xp3/ xp3plus that didn’t get the update that blocked installing 3rd party apps.
If anyone wants to try it, let us know what happens.
I don’t think there’s an older version that allowed
Additionally you can always install via adb
According to Reddit there was.
Question is if its image is around somewhere.
2 posts were merged into an existing topic: Rooting Sonim Xp3900
btw, i found a workaround for the xp3900, if anyone’s interested.
I’m interested
using shizuku and sai (split app installer).
feel free to figure it out yourself, otherwise i’ll hopefully get around to writing a guide sometime soon.
Nah I’ll wait for a guide I’m not so sophisticated
I workaround for what?
installing apps on the xp3plus
Adb?
from the phone itself without a computer.
I thought the app has to be signed by sonim at least on xp3800
I said I found a workaround for the xp3900 only.
