TCL Flip 2 Firmware
I got a TCL Flip 2. (Thank you, @anonymousfliphones)
Before I start experimenting with the firmware, I need the stock ROM so I can restore the device if anything gets damaged.
I couldn’t find it on the web, and I tried to back it up with MTKClient, but I got an error. It seems to require a custom DA, but the device is unlocked and not filtered.
Any help?
By “Stock ROM,” I mean the all the firmware, not just specific partitions (like boot, super, or recovery).
What software version do you have?
KEEZ software version
the T408DL doesnt have brom. you can root one and pull the partitions off
What’s brom?
its kind of where you can read and write data to the chip directly using tools like MTK client
  1. how to root?
  2. how to backup Stock? have another way? via SP flash? do you have a scatter?
To root you need neutron boot image check out github
flash neutron scott recovery and once in recovery pull all partitions
8 posts were split to a new topic: Enabling Debugging on the Newer TCL Flip Go
6 posts were split to a new topic: TCL Flip 2 Stuck in a Boot Loop
