TCL Flip 2: No Brom Mode, BUT
I didn’t even power on the phone — just straight into readback. Here’s a full dump of the TCL Flip 2, including the scatter file and everything you’ll need.
Nothing’s really kosher for me anymore, huh? Yeah, well… whatever. Enjoy.
And no — it won’t work with SP Flash Tool, don’t even try.
before updates
https://drive.google.com/file/d/1F4747biLckWbPoeiKsybxRizw7HOdVo4/view?usp=sharing
Those are different software versions if you plan on updating the software version you might want to do another read back after you update.
cool
how did you get a full readback without brom?
preloader
Whats that?
I WAS WAITING FOR THE QUESTION!!! You made my day!
Preloader… simple. So I can flash and read back any version with preloader mode…
And, I guess I’m pretty good at these things… yeah.
now get rid of simlock
Sure! What’s simlock? That it’s locked to a carrier?
yeah, tracfone
My ROM is a unlocked version, so flash all partitions via fastboot… simple.
will check if i have any locked ones lying around
once tried did 20 including nvram and still 20 to go but so far same Imei is the same
I have 2
There was never a full readback. Only SU_DD which is usually garbage…
what that?
adb shell
SU
dd if=/dev/block/by-name/<partition> of=/sdcard/<partition.img>
adb pull /sdcard/<partition>
In short you mean that dd Ing partitions wont take the Imei number?
Maybe, it’s not a good method…
Ok Will try your Rom, but I rather flash only the device unlock ones which could be?
