Uninstalling eGate
hi there i installed the filter made it device admin now i want to remove it from one of my devices how can i disable the app from being device admin?
There should be a button in the app to do that
If you have a new enough version, that is.
That’s also important when updating the filter to update it from the version you have, don’t go straight through the latest version
I Have an old version and im not sure what the next version is… is there any command i can run?
What phone are you using
a qin
Look for the version number in app info by settings
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
