35 Useful ADB Commands
This guide assumes you know what ADB is and how to use it. See this guide if you would like to learn more about ADB and how to use it: What is ADB and Getting Started - Android Guides - JTech Forums
1. Install an APK
adb install <path_to_apk>
Installs an APK from a specified path onto the device.
Arguments:
  • <path_to_apk>: The file path to the APK on the computer (e.g., C:\path\to\app.apk).
Example: adb install C:\path\to\app.apk
2. Uninstall an App
adb uninstall <package_name>
Uninstalls an app identified by its package name.
Arguments:
  • <package_name>: The package name of the app (e.g., com.example.app).
Example: adb uninstall com.example.app
3. Disable an App (User)
adb shell pm disable-user <package_name>
Disables a package for a specific user without uninstalling it.
Arguments:
Example: adb shell pm disable-user com.example.app
4. Enable an App (User)
adb shell pm enable <package_name>
Re-enables a disabled app for a specific user.
Arguments:
Example: adb shell pm enable com.example.app
5. Clear App Data
adb shell pm clear <package_name>
Clears all data associated with an app, resetting it to its default state.
Arguments:
Example: adb shell pm clear com.example.app
6. List All Installed Packages
adb shell pm list packages
Lists all installed package names on the device.
Arguments:
  • -f: Displays the path of the APK files along with the package name.
  • -3: Lists only third-party packages (not system apps).
Example: adb shell pm list packages -f
7. Get Device Information
adb shell getprop
Displays system properties, including device information.
Arguments:
  • None.
Example: adb shell getprop
8. Reboot the Device
adb reboot
Reboots the Android device.
Arguments:
  • None.
Example: adb reboot
9. Reboot into Recovery Mode
adb reboot recovery
Reboots the device into recovery mode.
Arguments:
  • None.
Example: adb reboot recovery
10. Reboot into Bootloader
adb reboot bootloader
Reboots the device into bootloader mode (fastboot).
Arguments:
  • None.
Example: adb reboot bootloader
11. Pull a File from the Device
adb pull <remote_path> <local_path>
Pulls a file from the Android device to your local machine.
Arguments:
  • <remote_path>: Path to the file on the device.
  • <local_path>: Path to where the file will be stored on the local machine.
Example: adb pull /sdcard/photo.jpg C:\path\to\save\
12. Push a File to the Device
adb push <local_path> <remote_path>
Pushes a file from the local machine to the Android device.
Arguments:
  • <local_path>: Path to the file on the local machine.
  • <remote_path>: Path where the file will be stored on the device.
Example: adb push C:\path\to\file.apk /sdcard/
13. List Connected Devices
adb devices
Lists all devices connected to your computer via ADB.
Arguments:
  • None.
Example: adb devices
14. Start an Activity
adb shell am start -n <package_name>/<activity_name>
Starts a specific activity within an app.
Arguments:
  • <package_name>: The package name of the app.
  • <activity_name>: The fully qualified name of the activity to start (e.g., .MainActivity).
Example: adb shell am start -n com.example.app/.MainActivity
15. Send a Key Event
adb shell input keyevent <keycode>
Simulates pressing a key on the device.
Arguments:
  • <keycode>: The keycode of the button (e.g., KEYCODE_HOME).
Example: adb shell input keyevent 3 (This simulates the Home button press)
16. Simulate Touch Event
adb shell input tap <x> <y>
Simulates a tap at the given (x, y) coordinates on the screen.
Arguments:
  • <x>: The X coordinate.
  • <y>: The Y coordinate.
Example: adb shell input tap 500 500
17. Simulate Swipe
adb shell input swipe <x1> <y1> <x2> <y2>
Simulates a swipe gesture from one point to another.
Arguments:
  • <x1>, <y1>: Starting coordinates.
  • <x2>, <y2>: Ending coordinates.
Example: adb shell input swipe 300 300 600 600
18. Logcat
adb logcat
Displays system log data, which can be useful for debugging.
Arguments:
  • -s <tag>: Filter logs by a specific tag.
  • -v <format>: Set the output format (e.g., long, brief, process).
Example: adb logcat -s ActivityManager:D (Filters logs by the ActivityManager tag)
19. Install APK with Option to Replace
adb install -r <path_to_apk>
Installs an APK, replacing an existing one if it is already installed.
Arguments:
  • <path_to_apk>: The file path to the APK on the computer.
Example: adb install -r C:\path\to\app.apk
20. Show Running Services
adb shell service list
Lists all the running services on the Android device.
Arguments:
  • None.
Example: adb shell service list
21. Capture Screenshot
adb shell screencap -p <local_path>
Takes a screenshot and saves it to the specified location on your computer.
Arguments:
  • <local_path>: The path where the screenshot will be saved (e.g., C:\path\to\screenshot.png).
Example: adb shell screencap -p C:\screenshot.png
22. Record Screen
adb shell screenrecord <remote_path>
Records the screen of the device to a file.
Arguments:
  • <remote_path>: Path on the device to save the recording.
Example: adb shell screenrecord /sdcard/demo.mp4
23. Reboot into Safe Mode
adb reboot safe
Reboots the device into Safe Mode.
Arguments:
  • None.
Example: adb reboot safe
24. Set System Property
adb shell setprop <property_name> <value>
Sets a system property on the device.
Arguments:
  • <property_name>: The property you want to set.
  • <value>: The value you want to assign to the property.
Example: adb shell setprop persist.sys.timezone "America/New_York"
25. Get System Property
adb shell getprop <property_name>
Retrieves the value of a system property.
Arguments:
  • <property_name>: The name of the property.
Example: adb shell getprop ro.build.version.release
26. Get Device Logs in a File
adb logcat -d > <path_to_log_file>
Save the current log output to a file.
Arguments:
  • <path_to_log_file>: Path where you want to save the log file.
Example: adb logcat -d > C:\path\to\log.txt
27. Run a Shell Command
adb shell <command>
Runs a command on the device through the shell.
Arguments:
  • <command>: The shell command to execute (e.g., ls, cat, etc.).
Example: adb shell ls /sdcard/
28. Enable/Disable Screen Timeout
adb shell settings put system screen_off_timeout <time_in_ms>
Sets the screen timeout period in milliseconds.
Arguments:
  • <time_in_ms>: Timeout in milliseconds.
Example: adb shell settings put system screen_off_timeout 600000 (sets timeout to 10 minutes)
29. Kill an App
adb shell am force-stop <package_name>
Kills the app by force stopping it.
Arguments:
Example: adb shell am force-stop com.example.app
30. Open Web Browser with URL
adb shell am start -a android.intent.action.VIEW -d <url>
Opens a specified URL in the browser.
Arguments:
  • <url>: The URL to open.
Example: adb shell am start -a android.intent.action.VIEW -d "https://www.google.com"
31. Set Airplane Mode
adb shell settings put global airplane_mode_on 1
Sets Airplane Mode on the device.
Arguments:
  • None.
Example: adb shell settings put global airplane_mode_on 1
32. Disable Wi-Fi
adb shell svc wifi disable
Disables Wi-Fi on the device.
Arguments:
  • None.
Example: adb shell svc wifi disable
33. Enable Wi-Fi
adb shell svc wifi enable
Enables Wi-Fi on the device.
Arguments:
  • None.
Example: adb shell svc wifi enable
34. Take Screenshot with Custom File Name
adb shell screencap -p /sdcard/<filename>.png
Takes a screenshot and saves it to a specified file on the device.
Arguments:
  • <filename>: The name for the screenshot file (e.g., screenshot1).
Example: adb shell screencap -p /sdcard/screenshot1.png
35. Restart ADB Server
adb kill-server && adb start-server
Restarts the ADB server.
Arguments:
  • None.
Example: adb kill-server && adb start-server
I hope this helped you learning about ADB!
